Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: I H TD6
PostPosted: Fri Dec 18, 2009 7:53 pm
Offline
Thanks given: 3
Thanks received: 21
Real name: Sean
Ih Martin, if your mooving them just to local jobs a tractor and low loader trailer is what i used to use also a mate had a unimog he sometimes let me use.If i went any distance i used a skip wagon and picked the drott up like a skip.Also martin i like how you have your machines in your garden,i may be looking for another drott to put in mine.Got pics of my old drott on trailer with unimog i will post.
sean :)
PostPosted: Sun Dec 20, 2009 12:36 am
Offline
Thanks given: 22
Thanks received: 22
Real name: MARTYN WILLIAMS
Hello Sean
Also looked for an decent plant trailer,the trouble was that when I wanted to sort out transport,another machine turned up :lol: .This has been going on for over 10 years now.
I have been very lucky in that my local council has been supporting me in moving my machines to council events.
One day I may get my own transport.
Cheers
Photo show my 933 turning up in Tiverton for its transfer to the lowloader and its trip to Wales.Billy Butt owns the County.My D4 came from the same yard.
PostPosted: Sun Dec 20, 2009 5:39 pm
Offline
Thanks given: 0
Thanks received: 3
Real name: DGL
On the subject of moving plant about with a trailer is it not the case that all trailers must have a manufacturer's plate on them now ? And that plate must comply with the statutory requirements and have been tested accordingly ?
And that failure to comply with this makes your insurance null and void ? I thought that we had reached this position now.
_________________
Image Image
PostPosted: Sun Dec 20, 2009 10:22 pm
Offline
Thanks given: 22
Thanks received: 22
The police do regular checks around here on tax,trucks and tractor hauled trailers.
I think the trailor regs. are on the DVLA website.
PostPosted: Sat Jan 30, 2010 9:23 pm
Offline
Thanks given: 0
Thanks received: 49
Hello Martyn
I had a1942 TD6 years ago. Rebuit the engine with a little help from my friends.
Failed to press out the liners tried to freeze them as well.
Ended up having them bored out,these days I would probably have run some welds in them to shrink them.
I have only one poor pic. of her with me in the saddle
in 1959/60.
Take no notice of the BTD6 transfer.
PostPosted: Fri Feb 19, 2010 9:36 pm
Offline
Thanks given: 22
Thanks received: 22
Got a replacement carb. for my TD6.made a hole in my wallet :(
PostPosted: Tue Mar 02, 2010 8:35 pm
Offline
Thanks given: 22
Thanks received: 22
Got all the bits I need for the TD6 now.Will put everything together next week and see if it will start.
PostPosted: Tue Mar 09, 2010 6:21 pm
Offline
Thanks given: 22
Thanks received: 22
Re built the carb and manifold this morning. Will see if the old girl will fire up on Thursday.Its been standing for two or three years so may take a bit of grunt on the starting handle.
Also progressed the D4,been sorting out the blade cutting edge.The bonnet is gone for shot blasting and a prime.
Hope this weather holds up.
PostPosted: Thu Mar 11, 2010 10:51 pm
Offline
Thanks given: 22
Thanks received: 22
Put all the serviced parts back on this afternoon ready to try for a start.The petrol filter bowl was found to be split :dizzy: Was OK when last down there.Looks the same size as a Fordson bowl,hopefully I may have a spare one that will fit.The spark plugs are the same as a D2 donkey engine.
PostPosted: Fri Mar 19, 2010 4:13 pm
Offline
Thanks given: 22
Thanks received: 22
Done a bit more on the TD6 this morning,sorted out the petrol pipework.Have now removed the mag. to check it as there is no spark. :(
Got home just in time as its now hammering down with rain.
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
