Reply to topic  [ 8 posts ]
Author Message
 Post subject: PATTISSON Turf Roller
PostPosted: Mon Jan 25, 2010 9:44 pm
Offline
Thanks given: 0
Thanks received: 12
Real name: John Turney
:) Hi, ended up giving this roller a home on Thursday. I have seen pictures and heard of the manufacturer before, H. Pattisson & Co.Ltd Stanmore Middx. Im guessing from the ser.no it could be 1959. It has a Ford Pop engine and their own gearbox.
Anybody got any more details. Will have to make more room in a shed!
Cheers John :rockon:
The following user would like to thank taurus MK1 for this post:
BulldozerD11
 Post subject: Re: PATTISSON Turf Roller
PostPosted: Mon Jan 25, 2010 10:54 pm
Offline
Thanks given: 157
Thanks received: 3
Real name: Dave
Hi John :thumbup:
looks an interesting 'contraption'
Not heard of Pattinson - any details John
Dave
_________________
PostPosted: Sat May 01, 2010 9:49 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: Jev
Hi.
I've got one of them!
Or rather my cricket club has one and it falls to me to keep it going with TLC.
Whereabouts in the country are you? There are so few pictures of this machine on the net.
I am near Huntingdon, Cambs.
PostPosted: Fri May 14, 2010 11:26 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: Jev
Bump
PostPosted: Sun May 23, 2010 9:10 pm
Offline
Thanks given: 0
Thanks received: 12
:wave: Hi Jev, sorry but just noticed that my reply to you did not get posted, i guess it got lost when the site went down.
The roller is in the shed, a future project, but many more in front. The engine i guess is a Ford Pop, im told it was all up and running beforeit was put away in a shed due to poor gaurding :o it came from a council owned golf range.
Cheers for now John
:rockon:
PostPosted: Sun May 23, 2010 11:14 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: Jev
Thanks for the reply, I think our messages did disappear into a hole when the site went down.
Our machine is a runner so if ever you want to see one running let me know, but based on your membership of this site you should find the roller fairly easy to maintain. The engine is the E93A (according to the transmission dipstick) which makes it a Ford Prefect or Popular? The one issue I have, although not a critical one, is that the left wheel brake doesn't work. You can see the movement of the shoe out towards the hub but virtually no brake force results. I am not confident enough to dismantle yet and check if some plonker has just let grease get in there?
I would also like to upgrade to 12 volt. I have the alternator & coil but no battery, but then worked out it requires some welding of a bracket to mount the alternator. However, it does start on a crank handle if required so I must be doing something right!
Our machine came from a country estate in the South East many years ago. It is diffucult to know how many years of hard work it had before us but the teeth have worn off the hand brake making it useless - then again our cricket ground is virtually flat after all! Our fuel tank is from a standing engine and is mounted right on top of the engine cover (rather than under it as was originally intended?)
Attached is a picture I found of another one - with tractor wheels rather than roller wheels & engine side panels - we never had any.
PostPosted: Wed Jun 02, 2010 4:20 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: Roddy MacDonald
Hi
Wondering if anyone can help me I bought a peice of equipment that was manufactured by H Pattisson & Co Ltd Stanmore hill works Stanmore Middx looking for a contact number for parts
Regards
Roddy
PostPosted: Wed Jun 02, 2010 9:08 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: Jev
Sorry - can't help you with spares contacts. I know of one other machine where the only chassis repair was made by a metal fabricator and a welding torch.
As for the engine & gearbox, they are "standard" Ford sidevalve prefect & popular parts. E93A engine in my machine.
Display posts from previous:  Sort by
Similar topics
Benford roller spare parts
Forum: Misc Compact Equipment/Attachments
Fordson Powered Roller
Forum: Paving Equipment
AVELING BARFORD ROLLER PROJECT
Forum: Projects
Looking for used roller in Germany
Marshall Fowler Roller
Users browsing this forum: dave fisher and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
