Reply to topic  [ 5 posts ]
Author Message
 Post subject: SERIAL PLATE?
PostPosted: Sun Mar 07, 2010 1:36 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: andy
hi all does anyone know where the id plate is for my 3cx4? ive been all over it and can not find one? it has a registration plate does that help?
any ideas appreciated
cheers
andy
 Post subject: Re: SERIAL PLATE?
PostPosted: Sun Mar 07, 2010 7:02 pm
Offline
Thanks given: 0
Thanks received: 2
Real name: steve
Hi Andy, I've got the same problem but with my 1976 3C II. Some numbers on the front n/s cross member casting but nothing resembleing a serial number according to the manual I downloaded from this site. However, today I took the panel off the front loader single control stick in the cab to change an O ring and saw 2 more sets of numbers on the casting. Not that yours will be the same set up but someone on here will know for sure.
Steve
PostPosted: Tue Mar 09, 2010 9:41 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: andy
any body got any ideas ? i need serial numbers to order parts apparently?
cheers
andy
PostPosted: Tue Mar 09, 2010 10:41 pm
Offline
Thanks given: 0
Thanks received: 0
Real name: john
hi Andy,
the serial plate should be on the beam below the front loader, behind the front wheel on the road side of the machine.
Thats where it is on mine. Yours could be painted over??
If you have a number plate, you could apply to the DVA for a lost/replacment V5(tax/log)book by phoning them, because the form you need isn't available for download (V55/c I think it is) at a cost of only £25, you might have to show insurance or SORN if not going to be on the public road.
The V5 will have the serial number(VIN)
hope this helps
John
_________________
1976 3C II
1977 JD 2130
1982 3CX4 sitemaster
1983 3CX
PostPosted: Thu Mar 11, 2010 10:01 am
Offline
Thanks given: 0
Thanks received: 0
Real name: andy
superb info
i will look when i get home on friday
i will have to ring to get a v5
many thanks
andy
Display posts from previous:  Sort by
Similar topics
Where is the serial number?
Forum: Loaders/Backhoes
No PLATE
Forum: Off Topic
serial numbers?
Forum: Excavators
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
